[mapguide][MG309][New] SetFeatureClassName() passing non-existing feature class in ...
Ronnie Louie
ronnie.louie at autodesk.com
Mon Jun 5 17:43:04 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG309
Type
Defect
Artifact ID
MG309 (SetFeatureClassName() passing non-existing feature class in SelectFeatures)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Summary set to new value
- Priority set to new value
P2
- External ID set to new value
793693 and 790101
- Target milestone set to new value
1.0.1
- Subcomponent set to new value
Feature Service
- Artifact created
- Resolution Description set to new value
Logic for setting the feature class name when feature source defines an extension. If using the extension, feature class name does not need to be set since feature reader will be populated with join result. The class name needs to be set when executing FdoSelectCommand for non-joined feature data.
- Steps to Reproduce set to new value
The FeatureService::SelectFeatures() API was passing a non-existing feature class name when selecting features from a join result (extension class).
- Component set to new value
Server
- Defect Severity set to new value
High
- Version set to new value
1.0.0
- Description set to new value
- Build set to new value
178.1
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
