[mapguide][MG309][Modified] SetFeatureClassName() passing non-existing feature class in ...
Ronnie Louie ronnie.louie at autodesk.com
Mon Jun 5 17:51:21 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG309
Type:
Defect
Artifact ID:
MG309 (SetFeatureClassName() passing non-existing feature class in SelectFeatures)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Steps to Reproduce set to new value:
Old value:
The FeatureService::SelectFeatures() API was passing a non-existing feature class name when selecting features from a join result (extension class).
New value:
1. Set an ODBC feature source as primary source for a join.
2. Set a different ODBC feature source and secondary source for a join.
3.  Create a layer based on the joined extension class.
4.  Notice layer preview does not display any features.
5.  Attempt to setup theming for the layer results in "Feature Class not found" error.
-- Developer Notes set to new value:
Partial fix which allows layer to display correctly and properties to display when feature is selected on the map.  Issue with theming still needs to be addressed because attempting to theme based on the secondary properties results in Parameter not Found error.  OK to theme based properties from the primary class.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
