[mapguide][MG311][New] Edit user screen contains bad links for Linux
Trevor Wekel
trevor.wekel at autodesk.com
Wed Jun 14 15:37:48 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG311
Type
Defect
Artifact ID
MG311 (Edit user screen contains bad links for Linux)
Reported by
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- OS Distribution and Version set to new value
All
- Platform set to new value
otherOS
- External ID set to new value
796218
- Operating system set to new value
Linux
- Subcomponent set to new value
Map Admin
- Priority set to new value
P2
- Defect Severity set to new value
Medium
- Version set to new value
1.0.0
- Target milestone set to new value
1.0.0
- Component set to new value
Web Server Extensions
- Steps to Reproduce set to new value
Log on to the web admin application on a MapGuide site that is running on Linux.
Select Manage Users, then select a user to edit.
Perform one of the following two actions:
- Make a change to any of the user's information, then click on Save, or
- click on the link "Home".
Expected result: The main Manage Users page to display. If the user's information was edited, the updated data should be visible.
Actual result: Apache throws a "404 - File not found" error. Investigating in the Apache error log shows that the page is attempting to load "UserManagement.php", but the filename is actually "usermanagement.php"--the link has the incorrect case for the filename.
If the web admin is running on a web tier configured on Windows, the case difference is ignored, and the product works as the user expects.
- Summary set to new value
- Developer Notes set to new value
the edituser.php script uses mixed case when referencing usermanagement.php
- Submission Reviewed set to new value
No
- Artifact created
- Description set to new value
Web admin Manage Users fails on Linux.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
