[mapguide][MG311][Modified] Edit user screen contains bad links for Linux
Trevor Wekel trevor.wekel at autodesk.com
Wed Jun 14 16:32:46 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG311
Type:
Defect
Artifact ID:
MG311 (Edit user screen contains bad links for Linux)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Code fix submitted.
-- Resolution set to new value:
Submitted
-- Developer Notes set to new value:
Old value:
the edituser.php script uses mixed case when referencing  usermanagement.php
New value:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Build set to new value:
178.5
-- Status Explanation set to new value:
Code fix submitted.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
