[mapguide][MG315][New] Remove provider version workaround
Bruce Dechant
bruce.dechant at autodesk.com
Wed Jun 21 12:29:08 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG315
Type
Defect
Artifact ID
MG315 (Remove provider version workaround)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Version set to new value
1.0.0
- Platform set to new value
All
- Steps to Reproduce set to new value
N/A
- Subcomponent set to new value
Core
- Operating system set to new value
All
- Component set to new value
Server
- Summary set to new value
- Artifact Status set to new value
New
- Defect Severity set to new value
Medium
- Priority set to new value
P3
- Description set to new value
The open source code had a provider version workaround because it was using the older FDO G001 providers. Since the code is being updated to the latest FDO R050 release the workaround in no longer needed and should be removed.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
