[mapguide][MG321][New] GetSchemaMapping API does not include "Default" spatial cont...
Bruce Dechant
bruce.dechant at autodesk.com
Fri Jun 30 12:51:59 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG321
Type
Defect
Artifact ID
MG321 (GetSchemaMapping API does not include "Default" spatial context in returned XML)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Version set to new value
1.0.0
- Artifact Status set to new value
New
- Defect Severity set to new value
Medium
- Description set to new value
The GetSchemaMapping API is used in the creation of configuration documents used by certain feature soruces(Example: Oracle). For some feature sources that only have 1 spatial context, ie: the "Default" this causes a problem because no spatial context is returned in the XML. Without a spatail context MapGuide cannot display any of the features.
- Steps to Reproduce set to new value
Execute the API and examine the returned XML. You will notice that the "Default" spatial context is missing.
- Subcomponent set to new value
Feature Service
- Component set to new value
Server
- Platform set to new value
All
- Summary set to new value
- Operating system set to new value
All
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
