[mapguide][MG42][New] SQLitePhpApi project file fix (+other project file cleanup)
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Mar 1 02:35:30 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG42
Type
OS:Issue
Artifact ID
MG42 (SQLitePhpApi project file fix (+other project file cleanup))
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- OS:Priority set to new value
P2
- OS:Target Milestone set to new value
1.0.0
- OS:Version set to new value
1.0.0
- OS:Platform set to new value
PC
- OS:Type set to new value
Task
- OS:Description set to new value
The debug build of the SQLitePhpApi PHP extension (php_SQLitePhpApid.dll) was failing to load. Using Depends I noticed that dependencies to msvcp80d and msvcr80d were missing. With VS 2005 these DLLs are referenced via the manifest. Sure enough, the debug configuration of the SQLitePhpApi project was not generating a manifest. After enabling it PHP was able to load the extension without problems.
- OS:Status set to new value
New
- OS:Summary set to new value
- OS:Resolution set to new value
Submitted
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
