[mapguide][MG43][New] Selection of SHP features in AJAX viewer only highlights sin...
Traian Stanev traian.stanev at autodesk.com
Wed Mar 1 11:17:19 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG43
Type
 OS:Issue
Artifact ID
 MG43 (Selection of SHP features in AJAX viewer only highlights single feature)
Reported by
 Traian Stanev
 traianstanev (traian.stanev at autodesk.com)
New artifact details:
- OS:Keywords set to new value
  AJAX viewer multiple select highlight
- OS:Resolution Description set to new value
When selecting features which should draw highlighted, we will simplify the FDO selection filter to not contain a spatial query portion. It is not really necessary anyway, since all it does is filter out features that are outside of the current view, but we do that in the rendering step also, so it's ok to remove.
- OS:Subcomponent set to new value
  Rendering Service
- OS:Target Milestone set to new value
  1.0.0
- OS:Summary set to new value
- OS:Description set to new value
  This is really a workaround for a bug in the FDO SHP provider where a combination of a feature ID and spatial query returns only one feature even if multiple features match the query.
- OS:Version set to new value
  1.0.0
- OS:Status set to new value
  New
- OS:Steps to Reproduce set to new value
  Rectangle select in AJAX viewer results in only one feature being highlighted even if multiple features are selected.
- OS:Priority set to new value
  P3
- OS:Platform set to new value
  ALL
- OS:Type set to new value
  Defect
- Artifact created
- OS:Component set to new value
  Server
- OS:Operating System set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
