[mapguide][MG47][New] Server crashes on certain layers viewed as DWF when zooming ...
Traian Stanev
traian.stanev at autodesk.com
Thu Mar 2 09:35:25 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG47
Type
Defect
Artifact ID
MG47 (Server crashes on certain layers viewed as DWF when zooming in.)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Operating system set to new value
All
- Target milestone set to new value
1.0.0
- Description set to new value
The server crashes in certain cases when a map with a polygon layer is zoomed in in such a way that some polygons have bounds that intersect the viewable area but are themselves outside of that area. (DWF output only)
- Version set to new value
1.0.0
- Artifact Status set to new value
New
- Subcomponent set to new value
Mapping Service
- Artifact created
- Component set to new value
Server
- Summary set to new value
- Priority set to new value
P1
- Steps to Reproduce set to new value
See above. You need a layer with complicated concave polygons to reproduce this. For example US states or Canada provinces.
Personally, I zoomed into Saskatchewan until it took the whole screen. This causes the crash to happen with good frequency.
- Defect Severity set to new value
Critical
- Platform set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
