[mapguide][MG47][Modified] Server crashes on certain layers viewed as DWF when zooming ...
Traian Stanev
traian.stanev at autodesk.com
Thu Mar 2 09:43:27 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG47
Type:
Defect
Artifact ID:
MG47 (Server crashes on certain layers viewed as DWF when zooming in.)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Resolution Description set to new value:
The problem was caused by a LineBuffer of size 0 being created. The 0 comes from the clipping code which sometimes clips a polygon out completely. The fix is to check for attempts to create LineBuffers of size 0 and bump it up to 2 points minimum. This will prevent the array resizing code from breaking.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
