[mapguide][MG49][New] ZoomToView in AJAX viewer does not always update a tiled vie...
Alain Lebatard alain.lebatard at autodesk.com
Thu Mar 2 13:32:17 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG49
Type
 Defect
Artifact ID
 MG49 (ZoomToView in AJAX viewer does not always update a tiled view)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Subcomponent set to new value
  AJAX Viewer
- Defect Severity set to new value
  Critical
- Component set to new value
  Web Server Extensions
- Description set to new value
  ZoomToView() is the javascript API that causes a change of view in the viewer, by specifying a center and a scale.
ZoomToView() implementation in the AJAX viewer does not refresh the view when the map is tiled and when there is no change of scale (only the view center changes).
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  In the sample application ajaxtiledviewersample.php:
  - execute the 'Navigate' command from the task menu
  - Click on 'District 1' -> the view is correctly updated
  - Click on 'District 2' -> the view is NOT updated
- Artifact created
- Summary set to new value
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
