[mapguide][MG52][New] OGC Web Map Service (WMS) 1.1.1 Compliance Updates
Chris Claydon
chris.claydon at autodesk.com
Thu Mar 2 16:31:31 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG52
Type
Defect
Artifact ID
MG52 (OGC Web Map Service (WMS) 1.1.1 Compliance Updates)
Reported by
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Description set to new value
The updates covered by this artifact will serve to increase the level of compliance with the OGC 1.1.1 compliance testing framework available at the following site:
http://cite.opengeospatial.org/test_engine/wms_1_1_1/wms_1_1_1.html
Specifically, we will now:
1) enforce the order of bounding box values specified in the BBOX parameter.
2) return service exceptions in the appropriate default format.
3) detect requests for unsupported image formats in the GetMap request type.
4) support the version 1.0.0 "WMTVER" parameter in cases where the newer "VERSION" parameter is not specified.
- Defect Severity set to new value
Low
- Steps to Reproduce set to new value
1) Upload CITE test data to server and configure as described in the compliance wesite.
2) Create manual/automated tests using the compliance website.
3) Observe test results for cases that test bounding boxes, image formats, exception formats, and versioning.
- Artifact created
- Summary set to new value
- Operating system set to new value
All
- Priority set to new value
P3
- Version set to new value
1.0.0
- Platform set to new value
All
- Subcomponent set to new value
OGC Interface
- Component set to new value
Web Server Extensions
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
