[mapguide][MG44][Modified] Defect 759243 GLOB: Garbled strings when server is down.
Trevor Wekel
trevor.wekel at autodesk.com
Thu Mar 2 17:46:06 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG44
Type:
OS:Issue
Artifact ID:
MG44 (Defect 759243 GLOB: Garbled strings when server is down.)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG44: Defect 759243 GLOB: Garbled strings when server is down.
Modified
File: trunk/MgDev/Common/Service/System/Resources.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/Resources.cpp?view=diff&rev=170&p1=trunk/MgDev/Common/Service/System/Resources.cpp&r1=169&p2=trunk/MgDev/Common/Service/System/Resources.cpp&r2=170
File: trunk/MgDev/Common/Service/System/Resources.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/Resources.h?view=diff&rev=170&p1=trunk/MgDev/Common/Service/System/Resources.h&r1=169&p2=trunk/MgDev/Common/Service/System/Resources.h&r2=170
File: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp?view=diff&rev=170&p1=trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp&r1=169&p2=trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp&r2=170
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
