[mapguide][MG54][Modified] Web surround sometimes displays wrong map size
Alain Lebatard
alain.lebatard at autodesk.com
Thu Mar 2 20:27:04 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG54
Type:
Defect
Artifact ID:
MG54 (Web surround sometimes displays wrong map size)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The map size units are now dynamic (as in MapGuide 6.5). It means that the surround displays the size in the most appropriate units. For example if the units are imperial and the width and height are less than 1 foot then the size is displayed in inches.
Possibility of display are miles (mi), feet (ft), inches (in), kilometers (km), meters (m) and centimeters (cm)
Fix also a buf in the viewer options UI. The code was using obsolete variables in the main frame.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
