[mapguide][MG51][Modified] Web Tier uses incorrect locale.
Steve Dang
steve.dang at autodesk.com
Thu Mar 2 20:58:21 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG51
Type:
Defect
Artifact ID:
MG51 (Web Tier uses incorrect locale.)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
Defect ID MG51: Web Tier uses incorrect locale.
Modified
File: trunk/MgDev/UnitTest/WebTier/Php/Utils.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/WebTier/Php/Utils.php?view=diff&rev=175&p1=trunk/MgDev/UnitTest/WebTier/Php/Utils.php&r1=174&p2=trunk/MgDev/UnitTest/WebTier/Php/Utils.php&r2=175
File: trunk/MgDev/Web/src/DotNetApi/ManagedException.cs https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/DotNetApi/ManagedException.cs?view=diff&rev=175&p1=trunk/MgDev/Web/src/DotNetApi/ManagedException.cs&r1=174&p2=trunk/MgDev/Web/src/DotNetApi/ManagedException.cs&r2=175
File: trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java?view=diff&rev=175&p1=trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java&r1=174&p2=trunk/MgDev/Web/src/JavaApi/org/osgeo/mapguide/AppThrowable.java&r2=175
File: trunk/MgDev/Web/src/mapadmin/login.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapadmin/login.php?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapadmin/login.php&r1=174&p2=trunk/MgDev/Web/src/mapadmin/login.php&r2=175
File: trunk/MgDev/Web/src/mapviewerjava/common.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/common.jsp?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerjava/common.jsp&r1=174&p2=trunk/MgDev/Web/src/mapviewerjava/common.jsp&r2=175
File: trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp&r1=174&p2=trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp&r2=175
File: trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp&r1=174&p2=trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp&r2=175
File: trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp&r1=174&p2=trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp&r2=175
File: trunk/MgDev/Web/src/mapviewernet/common.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/common.aspx?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewernet/common.aspx&r1=174&p2=trunk/MgDev/Web/src/mapviewernet/common.aspx&r2=175
File: trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx&r1=174&p2=trunk/MgDev/Web/src/mapviewernet/gettingstarted.aspx&r2=175
File: trunk/MgDev/Web/src/mapviewernet/mainframe.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/mainframe.aspx?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewernet/mainframe.aspx&r1=174&p2=trunk/MgDev/Web/src/mapviewernet/mainframe.aspx&r2=175
File: trunk/MgDev/Web/src/mapviewernet/mapframe.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/mapframe.aspx?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewernet/mapframe.aspx&r1=174&p2=trunk/MgDev/Web/src/mapviewernet/mapframe.aspx&r2=175
File: trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx&r1=174&p2=trunk/MgDev/Web/src/mapviewernet/serveradminhelper.aspx&r2=175
File: trunk/MgDev/Web/src/mapviewerphp/common.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/common.php?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerphp/common.php&r1=174&p2=trunk/MgDev/Web/src/mapviewerphp/common.php&r2=175
File: trunk/MgDev/Web/src/mapviewerphp/gettingstarted.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/gettingstarted.php?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerphp/gettingstarted.php&r1=174&p2=trunk/MgDev/Web/src/mapviewerphp/gettingstarted.php&r2=175
File: trunk/MgDev/Web/src/mapviewerphp/mainframe.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/mainframe.php?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerphp/mainframe.php&r1=174&p2=trunk/MgDev/Web/src/mapviewerphp/mainframe.php&r2=175
File: trunk/MgDev/Web/src/mapviewerphp/mapframe.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/mapframe.php?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerphp/mapframe.php&r1=174&p2=trunk/MgDev/Web/src/mapviewerphp/mapframe.php&r2=175
File: trunk/MgDev/Web/src/mapviewerphp/serveradminhelper.php https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapviewerphp/serveradminhelper.php?view=diff&rev=175&p1=trunk/MgDev/Web/src/mapviewerphp/serveradminhelper.php&r1=174&p2=trunk/MgDev/Web/src/mapviewerphp/serveradminhelper.php&r2=175
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
