[mapguide][MG56][New] Fix broken mapagent installation on Linux
Trevor Wekel trevor.wekel at autodesk.com
Thu Mar 2 21:01:43 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG56
Type
 Task
Artifact ID
 MG56 (Fix broken mapagent installation on Linux)
Reported by
 Trevor Wekel
 trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Target milestone set to new value
  1.0
- Summary set to new value
- Artifact created
- Description set to new value
  The mapagent on Linux does not start up.  This is an installation related problem with symlinks and the placeholder mapagent.fcgi file.  The placeholder fcgi is not required on Linux.
- Need By Date set to new value
  2006-03-03
- Task Priority set to new value
  High
- Status Explanation set to new value
  With the state of the current install, the mapagent does not execute out of the box.
- Artifact Status set to new value
  New
- Priority set to new value
  P2
- Submission Reviewed set to new value
  No
- Integration and Build Notes set to new value
  This submission changes the make install procedure for the Web Server Extensions.
Reason:
This install procedure fix is critical for a successful "out of the box" install.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
