[mapguide][MG56][Modified] Fix broken mapagent installation on Linux
Trevor Wekel
trevor.wekel at autodesk.com
Fri Mar 3 00:19:47 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG56
Type:
Defect
Artifact ID:
MG56 (Fix broken mapagent installation on Linux)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Version set to new value:
1.0.0
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Build set to new value:
164.5
-- Defect Severity set to new value:
High
-- Operating system set to new value:
Linux
-- Resolution Description set to new value:
Code fix submitted.
-- Subcomponent set to new value:
Map Agent
-- Steps to Reproduce set to new value:
Build on Linux from the LinuxApt tarball and the source tar ball according to our documented process. After installation, mapagent will not function.
-- Platform set to new value:
PC
-- Target milestone set to new value:
1.0.0
-- Component set to new value:
Web Server Extensions
-- Resolution set to new value:
Submitted
Reason:
Code fix submitted. Artifact updated.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
