[mapguide][MG57][New] Missing check for null FeatureTypeStyle in legend image code
Traian Stanev
traian.stanev at autodesk.com
Fri Mar 3 10:10:48 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG57
Type
Defect
Artifact ID
MG57 (Missing check for null FeatureTypeStyle in legend image code)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Resolution set to new value
Submitted
- Summary set to new value
- Operating system set to new value
All
- Description set to new value
There was a call to determine the type of a feature type style that assumed the Mdf FeatureTypeStyle object is not null, when in some cases it could be.
- Artifact Status set to new value
New
- Defect Severity set to new value
High
- Platform set to new value
All
- Component set to new value
Server
- Priority set to new value
P2
- Subcomponent set to new value
Mapping Service
- Artifact created
- Resolution Description set to new value
I removed the call since it was not needed -- it was part of a TODO.
Also enabled legend images for raster layers, which was part of the same TODO.
- Target milestone set to new value
1.0.0
- Steps to Reproduce set to new value
Tom Fukushima has a layer (from Oracle) with no feature type styles, which was causing the crash.
- Version set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
