[mapguide][MG58][New] Fix release build of SQLiteDotNet in Oem
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Mar 3 12:30:15 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG58
Type
 Defect
Artifact ID
 MG58 (Fix release build of SQLiteDotNet in Oem)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
  It never ends with these SQLite projects...
If you attempt to build the release configuration of oem.sln, you get an error with the SQLiteDotNet project.  It's referencing the ACE library, but that library has not yet been built.
- Resolution Description set to new value
  The reference to the ACE library in SQLiteDotNet has been removed - it's not needed.  Also noticed that the SQLiteUnitTest references the CppUnit library, but CppUnit was not listed as a dependency.  The build order happened to be ok in this case.  Nevertheless, it needs tobe added as a dependency.
- Steps to Reproduce set to new value
  Try building the release configuration of oem.sln.  The SQLiteDotNet project generates an error.
- Artifact created
- Defect Severity set to new value
  High
- Resolution set to new value
  Submitted
- Operating system set to new value
  Windows XP
- Target milestone set to new value
  1.0.0
- Platform set to new value
  PC
- Artifact Status set to new value
  New
- Priority set to new value
  P2
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
