[mapguide][MG58][Modified] Fix release build of SQLiteDotNet in Oem
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 3 12:34:18 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG58
Type:
Defect
Artifact ID:
MG58 (Fix release build of SQLiteDotNet in Oem)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
It never ends with these SQLite projects...
If you attempt to build the release configuration of oem.sln, you get an error with the SQLiteDotNet project. It's referencing the ACE library, but that library has not yet been built.
New value:
This fix is needed for the Windows open source build.
-- Status Explanation set to new value:
The code changes have been submitted.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
