[mapguide][MG61][Modified] Fix open source build issues
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Mar 3 14:52:44 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG61
Type:
Defect
Artifact ID:
MG61 (Fix open source build issues)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Old value:
Code fixes have been submitted.
New value:
The names of the missing .rc files have been added to the EXTRA_DIST setting in the corresponding Makefile.am files.
There were also two Java files that were missing from the distribution:
  MgBase64.java
  MgLocalizer.java
The JavaApi project builds fine without these files, but attempting to run the generated JAR file will result in a runtime error.
-- Status Explanation set to new value:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
