[mapguide][MG62][New] Remove ACE project from server solution
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 3 15:02:03 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG62
Type
Defect
Artifact ID
MG62 (Remove ACE project from server solution)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Target milestone set to new value
1.0.0
- Artifact created
- Operating system set to new value
Windows XP
- Resolution set to new value
Submitted
- Priority set to new value
P4
- Defect Severity set to new value
Low
- Version set to new value
1.0.0
- Platform set to new value
PC
- Component set to new value
Server
- Summary set to new value
- Description set to new value
The ACE project is part of the server solution, yet it's not being built. It was originally added for convenience so developers could easily access the ACE code, but at this point it's no longer needed. It also increases the length of time it takes Visual Studio to do its dependency processing.
- Artifact Status set to new value
New
- Steps to Reproduce set to new value
Open the server project and notice ACE as the first project.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
