[mapguide][MG62][Modified] Remove ACE project from server solution
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 3 15:04:37 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG62
Type:
Defect
Artifact ID:
MG62 (Remove ACE project from server solution)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Status Explanation set to new value:
Code fixes have been submitted for the Server Community solution.
-- Resolution Description set to new value:
I removed the ACE project from the solution. After doing this any project which had a reference to ACE (via a project dependency) would fail to link. To fix this I had to update these projects to explicitly list the ACE library as an input library.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
