[mapguide][MG63][New] Missing libraries in the Mapguide Open Source installation
Vishal Bangia
vishal.bangia at autodesk.com
Fri Mar 3 16:04:39 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG63
Type
Defect
Artifact ID
MG63 (Missing libraries in the Mapguide Open Source installation)
Reported by
Vishal Bangia
vishalbangia (vishal.bangia at autodesk.com)
New artifact details:
- Defect Severity set to new value
High
- Operating system set to new value
Linux
- Description set to new value
The make install command does not install the following binaries
a) libdbxml*.so
b) libdb_cxx*.so
Other Changes :
Fixed a typo in a comment in build_oem.sh
- Submission Reviewed set to new value
No
- Subcomponent set to new value
General
- Target milestone set to new value
1.0.0
- Artifact created
- Platform set to new value
PC
- Integration and Build Notes set to new value
make install now works correctly.
- Version set to new value
1.0.0
- Resolution set to new value
Submitted
- Priority set to new value
P3
- Component set to new value
Server
- Artifact Status set to new value
New
- Resolution Description set to new value
changed MgDev/Oem/Makefile.am
install-exec-am: hook to copy the missing libraries to the install location.
- Steps to Reproduce set to new value
run ldd on the installed mgserver binary and inspect the output.
The above two binaries are located to where they are built.
- OS Distribution and Version set to new value
Redhat 3.0
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
