[mapguide][MG12][Modified] Specifying a center/scale in a web layout may cause the map ...
Trevor Wekel trevor.wekel at autodesk.com
Fri Mar 3 19:32:36 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG12
Type:
OS:Issue
Artifact ID:
MG12 (Specifying a center/scale in a web layout may cause the map not to show)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Reviewed.  Looks ok.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
