[mapguide][MG65][New] Java API does not build or work on Linux
Trevor Wekel trevor.wekel at autodesk.com
Sat Mar 4 15:28:07 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG65
Type
 Defect
Artifact ID
 MG65 (Java API does not build or work on Linux)
Reported by
 Trevor Wekel
 trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- Subcomponent set to new value
  Web API
- Operating system set to new value
  Linux
- Priority set to new value
  P1
- Platform set to new value
  All
- Submission Reviewed set to new value
  No
- Version set to new value
  1.0.0
- Summary set to new value
- Artifact created
- Description set to new value
  Due to redistribution restrictions, the Oem/Java directory was removed from Subversion.  The build process was not updated to use the JDK in JAVA_HOME.    As such, the Web Extension JavaAPI would not build or run on Linux.
- Component set to new value
  Web Server Extensions
- Steps to Reproduce set to new value
  Follow our standard building on Linux steps.  The JavaAPI is not usable, nor is mapviewerjava.
- Artifact Status set to new value
  New
- Target milestone set to new value
  1.0.0
- Defect Severity set to new value
  Critical
- Developer Notes set to new value
  This submission should fix JavaAPI on Linux.  More testing from a newly generated tarball is required.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
