[mapguide][MG28][Modified] Search UI display internal command name instead of display n...
Trevor Wekel
trevor.wekel at autodesk.com
Sat Mar 4 17:23:50 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG28
Type:
OS:Issue
Artifact ID:
MG28 (Search UI display internal command name instead of display name)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Reviewed. Ok.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
