[mapguide][MG41][Modified] Each command in the getting started should display an icon
Trevor Wekel trevor.wekel at autodesk.com
Sat Mar 4 17:31:51 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG41
Type:
OS:Issue
Artifact ID:
MG41 (Each command in the getting started should display an icon)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Reviewed.  Ok.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
