[mapguide][MG72][Modified] KB912945 update interferes with DWF-Viewer-based web layouts
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Mar 6 18:01:44 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG72
Type:
Defect
Artifact ID:
MG72 (KB912945 update interferes with DWF-Viewer-based web layouts)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Status Explanation set to new value:
Initially assigning this to Alain so he can determine if changes to the web surround are needed. I did test a simple web page that embedded the DWF Viewer, and after clicking in the control window the DWF Viewer control did start up ok.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
