[mapguide][MG74][New] AJAX viewer does not display tooltips for line and point fea...
Alain Lebatard alain.lebatard at autodesk.com
Mon Mar 6 18:25:28 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG74
Type
 Defect
Artifact ID
 MG74 (AJAX viewer does not display tooltips for line and point features)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Component set to new value
  Web Server Extensions
- Artifact created
- Summary set to new value
- Subcomponent set to new value
  AJAX Viewer
- Description set to new value
  Tooltips are not displayed for point and line features in the AJAX viewer.
The viewer currently passes a POINT geometry (the mouse cursor translated to map units) to the server to get tooltip information. This makes it almost impossible to be at the exact location of the feature. The viewer should pass a rectangle geometry instead, providing some tolerance allowing to find the point or line feature at that location.
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  Make roads selectable in sheboygan.
Load the Sheboygan layout in the web browser.
Move the cursor above a road => no matter how close the cursor seems to be from the road, no tooltip appear
- Defect Severity set to new value
  Medium
- Priority set to new value
  P2
- Version set to new value
  0.9.1
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
