[mapguide][MG76][New] AJAX Viewer status bar shows "(Degree)"
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Mar 7 00:58:30 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG76
Type
Defect
Artifact ID
MG76 (AJAX Viewer status bar shows "(Degree)")
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Component set to new value
Web Server Extensions
- Description set to new value
The AJAX viewer web layout status bar shows "(Degree)" next to the lat/lon coordinates, while the DWF Viewer web layout status bar shows "(degrees)". The latter is the correct string.
- Priority set to new value
P3
- Operating system set to new value
Windows XP
- Steps to Reproduce set to new value
USe the AJAX viewer to open a web layout from the Sheboygan sample data, and look at the status bar.
- Summary set to new value
- Version set to new value
1.0.0
- Platform set to new value
PC
- Target milestone set to new value
1.0.0
- Defect Severity set to new value
Medium
- Artifact created
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
