[mapguide][MG75][Modified] Web layout status bar does not correctly show position
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Mar 7 00:59:21 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG75
Type:
Defect
Artifact ID:
MG75 (Web layout status bar does not correctly show position)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The position indicator on the status bar only shows "(Degrees)" with the Sheboygan map. Also the "Powered by MapGuide" icon is missing. This happens:
- when previewing a web layout in Studio or viewing it in a separate browser instance
- with both IE and Firefox
- with both DWF and AJAX Viewer
This is a recently introduced regression. It doesn't cause a crash, but it's a high-visibility defect that, IMO, should be fixed for our final 1.0.0 release.
UPDATE - 3/7/06: this is mostly fixed in build 165.1. Still broken:
- the AJAX viewer web layout status bar shows "(Degree)" next to the lat/lon coordinates, while the DWF Viewer web layout status bar shows "(degrees)". The latter is the correct string.
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
