[mapguide][MG78][New] DWF Viewer complains when EMap contains too many themes
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Mar 7 14:12:46 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG78
Type
 Defect
Artifact ID
 MG78 (DWF Viewer complains when EMap contains too many themes)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Resolution set to new value
  External
- Artifact Status set to new value
  New
- Component set to new value
  Viewer
- Description set to new value
  If an EMap contains a lot of resources (e.g. legend images for themes) then it's possible the viewer will display an error dialog.  The message says "There was an error loading the map", and the details say "Unrecognized or unexpected sequence in stream".
After pressing Ok to get rid of the dialog, the map should finish loading without problems.
- Version set to new value
  1.0.0
- Target milestone set to new value
  1.0.0
- Priority set to new value
  P3
- Artifact created
- Subcomponent set to new value
  DWF Viewer
- Operating system set to new value
  Windows XP
- Summary set to new value
- Defect Severity set to new value
  Medium
- Platform set to new value
  PC
- Steps to Reproduce set to new value
  Run DWF Viewer in standalone mode and open the attached EMap DWF.  You should get the error dialog.
NOTE: after opening the attached DWF you'll also get a "map server" dialog indicating the session has expired.  This can be ignored.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
