[mapguide][MG74][Modified] AJAX viewer does not display tooltips for line and point fea...
Alain Lebatard
alain.lebatard at autodesk.com
Wed Mar 8 13:46:27 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG74
Type:
Defect
Artifact ID:
MG74 (AJAX viewer does not display tooltips for line and point features)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Version changed:
Old value:
0.9.1
New value:
1.0.0
-- Resolution Description set to new value:
The request for tooltip information now passes a small rectangle instead of a point to mach the featrue under the cursor.
Also, fixes the list of layers passed to this requuest. The list of visible/selectable layer was passed, although there is no requirement for a layer to be selectable to display tooltip information.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
