[mapguide][MG82][New] Fill patterns not rendering with point symbols
Tom Fukushima
tom.fukushima at autodesk.com
Wed Mar 8 18:08:18 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG82
Type
Defect
Artifact ID
MG82 (Fill patterns not rendering with point symbols)
Reported by
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
New artifact details:
- Subcomponent set to new value
Rendering Service
- Defect Severity set to new value
Medium
- Steps to Reproduce set to new value
1) Create a point layer
2) Set the fill style to be a fill pattern other than solid
3) Render the layer.
- Component set to new value
Server
- OS Distribution and Version set to new value
Pro SP2
- Artifact Status set to new value
New
- Artifact created
- Operating system set to new value
Windows XP
- Version set to new value
1.0.0
- Platform set to new value
PC
- Summary set to new value
- Description set to new value
If a point symbol is defined such that it has a fill pattern, the symbol is not rendered with that pattern, but instead contains a white solid fill. The behavior is same in both the raster maps and eMaps.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
