[mapguide][MG68][Modified] Undefined exception raised when doing coordinate system tran...
Bruce Dechant bruce.dechant at autodesk.com
Wed Mar 8 21:30:42 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG68
Type:
Defect
Artifact ID:
MG68 (Undefined exception raised when doing coordinate system transformation)
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Code has been fixed.
-- Developer Notes set to new value:
Retested the coordinate system unit tests and they all passed. Also tested the use case given and the "New" exception is thrown and caught.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
