[mapguide][MG83][Modified] Unit string always shown as degrees in status bar with DWF v...
Traian Stanev traian.stanev at autodesk.com
Thu Mar 9 09:28:14 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG83
Type:
Defect
Artifact ID:
MG83 (Unit string always shown as degrees in status bar with DWF viewer)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Obtain unit string from coord sys object and pass it on to stylization via the RS_MapUIInfo structure.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
