[mapguide][MG85][New] Better display of coordinate system units in status bar
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 9 11:34:51 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG85
Type
Enhancement
Artifact ID
MG85 (Better display of coordinate system units in status bar)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Description set to new value
The web layout status bar displays the current mouse position as a string with the form:
X: #.#, Y: #.# (<CS units>)
Some examples:
X: -85.5, Y: 42.1 (Degree)
X: 1000000.0, Y: 1000000.0 (Foot_US)
X: 1969052.879314, Y: 636491.372683 (Meter)
The <CS units> string that gets displayed is the raw string that's defined with the coordinate system.
I would suggest the following changes to the units that get displayed:
- make them plural
- use lower case (when appropriate)
- allow them to be globalized
The above examples would then look like:
X: -85.5, Y: 42.1 (degrees)
X: 1000000.0, Y: 1000000.0 (US feet)
X: 1969052.879314, Y: 636491.372683 (meters)
- Summary set to new value
- Priority set to new value
P4
- Artifact Status set to new value
New
- Justification set to new value
Having the units be plural and lower case makes the string be more readable. It's a subjective thing.
Allowing the strings to be globalized is more important though.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
