[mapguide][MG86][Modified] Previewing a layer/map doesn't work in Studio with Web Exten...
Hartesh Chhabra
hartesh.chhabra at autodesk.com
Thu Mar 9 12:00:46 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG86
Type:
Defect
Artifact ID:
MG86 (Previewing a layer/map doesn't work in Studio with Web Extensions Java environment)
Modified by:
Hartesh Chhabra
harteshchhabra (hartesh.chhabra at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
We need to add following statements to httpd.conf file-
#This is for previewing maps in Studio using AJAX viewer
Redirect /mapguide/mapviewerajax/ http://servername:8008/mapguide/mapviewerjava/ajaxviewer.jsp -
-- Description set to new value:
Old value:
Studio uses follwing aliases to preview layer/map
New value:
#This is for previewing maps in Studio using DWF viewer
Redirect /mapguide/mapviewerdwf/ http://servername:8008/mapguide/mapviewerjava/dwfviewer.jsp
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
