[mapguide][MG87][New] Bitonal raster images sometimes display as garbage when usin...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 9 17:23:02 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG87
Type
Defect
Artifact ID
MG87 (Bitonal raster images sometimes display as garbage when using the DWF viewer)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Description set to new value
When viewing a layer for a bitonal raster the DWF Viewer sometimes shows garbage. It doesn't happen all time - just at certain zoom levels / screen widths.
It looks there's a logic error when process the raster.
- Subcomponent set to new value
Core
- Artifact created
- Component set to new value
Server
- Version set to new value
1.0.0
- Resolution set to new value
Submitted
- Platform set to new value
All
- Steps to Reproduce set to new value
Create a raster layer pointing to a bitonal image, and view the layer (using Studio or create a map/web layout that references that layer). Be sure to use DWF Viewer to view the layer. Keep adjusting the window size until you see a garbage raster.
- Resolution Description set to new value
Code fix has been submitted in the trunk.
- Summary set to new value
- Operating system set to new value
All
- Artifact Status set to new value
New
- Priority set to new value
P2
- Defect Severity set to new value
High
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
