[mapguide][MG87][Modified] Bitonal raster images sometimes display as garbage when usin...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 9 17:26:10 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG87
Type:
Defect
Artifact ID:
MG87 (Bitonal raster images sometimes display as garbage when using the DWF viewer)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
When viewing a layer for a bitonal raster the DWF Viewer sometimes shows garbage. It doesn't happen all time - just at certain zoom levels / screen widths.
It looks there's a logic error when process the raster.
New value:
It looks like there's a logic error when process the raster.
-- Status Explanation set to new value:
Code fix has been submitted to the trunk stream.
-- Developer Notes set to new value:
The bug was caused by a logic error in RasterAdapter::DecodeBitonal. In the case where the requested image width was a multiple of 8, the code would miss one byte of data at the end of each row.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
Old value:
Code fix has been submitted in the trunk.
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
