[mapguide][MG89][New] Fix memory leak in coordinate system transform
Bruce Dechant
bruce.dechant at autodesk.com
Thu Mar 9 18:50:16 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG89
Type
Defect
Artifact ID
MG89 (Fix memory leak in coordinate system transform)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Summary set to new value
- Steps to Reproduce set to new value
Run the server /testmode from within a debugger.
The debugger will report a small leak for everytime this API was called.
- Platform set to new value
All
- Defect Severity set to new value
Low
- Description set to new value
There is a memory leak in the MgEnvelope* MgCoordinateSystemTransform::Transform(MgEnvelope* envelope) method. It is not deleting a CEnvelope object.
Note: This leak only applies to 3D transforms.
- Operating system set to new value
All
- Target milestone set to new value
1.0.1
- Version set to new value
1.0.0
- Artifact created
- Artifact Status set to new value
New
- Subcomponent set to new value
Core
- Component set to new value
Server
- Priority set to new value
P3
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
