[mapguide][MG92][New] Base layer group doesn't display if name contains a ")"
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 10 16:56:26 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG92
Type
Defect
Artifact ID
MG92 (Base layer group doesn't display if name contains a ")")
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Platform set to new value
All
- Priority set to new value
P2
- Version set to new value
1.0.0
- Operating system set to new value
All
- Artifact created
- Defect Severity set to new value
High
- Summary set to new value
- Component set to new value
Web Server Extensions
- Artifact Status set to new value
New
- Steps to Reproduce set to new value
Create a map containing a base layer group that has the ")" character in it, and preview the map.
The tiles for the base layer group will not display.
- Subcomponent set to new value
AJAX Viewer
- Description set to new value
A map containing a base layer group that has the ")" character in the group name fails to display the tiles for that group.
Examples I verified failed:
"Base Layer Group (1)"
"Base Layer) Group"
The former is troubling because this is the name Studio uses when adding the second base layer group.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
