[mapguide][MG97][New] Base layer has wrong initial visibility in EMap
Walt Welton-Lair walt.welton-lair at autodesk.com
Sat Mar 11 01:49:21 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG97
Type
 Defect
Artifact ID
 MG97 (Base layer has wrong initial visibility in EMap)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Version set to new value
  1.0.0
- Summary set to new value
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  - create a map with a single base layer group containing a single layer
- set the base layer group's initial visibility to false and the layer's to true
- create a web layout for the map, and preview it with the DWF Viewer
=> the DWF Viewer's legend is empty
=> it should contain both the group (unchecked) and the layer (gray check)
- Platform set to new value
  All
- Operating system set to new value
  All
- Component set to new value
  Server
- Priority set to new value
  P3
- Artifact created
- Subcomponent set to new value
  Mapping Service
- Defect Severity set to new value
  Medium
- Developer Notes set to new value
  This is a server bug.  The layer visibility ends up being false in the EMap when it should be true.
- Description set to new value
  See steps to reproduce.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
