[mapguide][MG101][New] MgLayer::IsVisibleAtScale has incorrect logic
Walt Welton-Lair walt.welton-lair at autodesk.com
Mon Mar 13 11:49:51 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG101
Type
 Defect
Artifact ID
 MG101 (MgLayer::IsVisibleAtScale has incorrect logic)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Priority set to new value
  P2
- Artifact Status set to new value
  New
- Component set to new value
  Server
- Subcomponent set to new value
  Core
- Description set to new value
  The MgLayer::IsVisibleAtScale() method has the following block of code:
    if(group == NULL)
        return true;
    else
        return group->IsVisible();
This code always returns - the code which does the scale range check further down is unreachable.
The fix is to replace the above block of code with:
    if(group && !group->IsVisible())
        return false;
- Summary set to new value
- Version set to new value
  1.0.0
- Operating system set to new value
  All
- Artifact created
- Defect Severity set to new value
  High
- Platform set to new value
  All
- Steps to Reproduce set to new value
  See description above
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
