[mapguide][MG103][New] WMS 1.1.1 Compliance Updates
    Chris Claydon
    chris.claydon at autodesk.com
    Mon Mar 13 14:17:37 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG103
Type
 Defect
Artifact ID
 MG103 (WMS 1.1.1 Compliance Updates)
Reported by
 Chris Claydon
 chrisclaydon (chris.claydon at autodesk.com)
New artifact details:
- Version set to new value
  1.0.0
- Subcomponent set to new value
  OGC Interface
- Artifact created
- Summary set to new value
- Target milestone set to new value
  1.0.1
- Platform set to new value
  All
- Steps to Reproduce set to new value
  1) Execute a GetMap request that includes a specific layer style, using the STYLES parameter. Currently, only default styles are supported, so specifying any string value ought to return a service exception. Before these changes, the STYLES parameter was simply ignored.
2) Execute WMS requests for GetCapabilities without specifying a FORMAT parameter, using the VERSION parameter to specify each of the VERSIONS 1.0.0, 1.1.0 and 1.1.1. Prior to these changes, all versions will return text/xml content. After these changes, the later two versions will return application/vnd.ogc.wms_xml.
- Priority set to new value
  P3
- Artifact Status set to new value
  New
- Component set to new value
  Web Server Extensions
- Description set to new value
  These changes modify support for WMS requests so that:
1) Requests for unsupported layer styles return a service exception with error code "StyleNotDefined".
2) The default format returned for GetCapabilities is text/xml for version 1.0.0 requests, and application/vnd.ogc.wms_xml for 1.1.0 and 1.1.1 requests. Note that text/xml is still supported for 1.1.0 and 1.1.1 is explicitly requested using the FORMAT parameter.
- Defect Severity set to new value
  Low
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
