[mapguide][MG105][New] QueryFeatures does not honor maximum feature limit
Alain Lebatard alain.lebatard at autodesk.com
Mon Mar 13 19:49:06 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG105
Type
 Defect
Artifact ID
 MG105 (QueryFeatures does not honor maximum feature limit)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Subcomponent set to new value
  Rendering Service
- Description set to new value
  A request to QUERYMAPFEATURES with a parameter MAXFEATURES set to 1 can return more than 1 feature.
- Platform set to new value
  All
- Defect Severity set to new value
  High
- Steps to Reproduce set to new value
  In Sheboygan sample application, make Railroad selectable.
Open Sheboygan sample app for AJAX
Zoom to parcel level where you can see a railroad
Click-select the railroad
  => 2 features are selected, the railroad and the parcel underneath.
The AJAX viewer makes the request with MAXFEATURES=1, so only the first matching feature should be returned, the railroad in that case since it is higher in the drawing order.
- Summary set to new value
- Component set to new value
  Server
- Priority set to new value
  P2
- Artifact created
- Version set to new value
  1.0.0
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
