[mapguide][MG106][New] Display of map height in status bar incorrect with DWF Viewe...
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Mar 14 00:24:22 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG106
Type
 Defect
Artifact ID
 MG106 (Display of map height in status bar incorrect with DWF Viewer-based web layouts)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Target milestone set to new value
  1.0.1
- Platform set to new value
  All
- Operating system set to new value
  All
- Defect Severity set to new value
  Medium
- Description set to new value
  With web layouts the status bar displays the width/height of the map extent, e.g. "9.29 x 8.76 (mi)".  Since the map extent is fixed, changing the window size or view should not cause this value to change.  With DWF Viewer-based web layouts, however, the displayed value of the map height seems to be view dependent.
- Summary set to new value
- Artifact created
- Version set to new value
  1.0.0
- Component set to new value
  Viewer
- Subcomponent set to new value
  General
- Priority set to new value
  P4
- Steps to Reproduce set to new value
  1/ Open a DWF Viewer based web layout and note the value of the map width/height in the status bar.
2/ Adjust the vertical size of the browser window, and recheck the map height displayed in the status bar.
=> it shows a different value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
