[mapguide][MG108][Modified] Mark Symbol changes not saved; removed fills and edges displ...
Ben Trumbore ben.trumbore at autodesk.com
Tue Mar 14 14:49:48 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG108
Type:
Defect
Artifact ID:
MG108 (Mark Symbol changes not saved; removed fills and edges displayed anyway.)
Modified by:
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
more to come
New value:
When a MarkSymbol's fill or edge is disabled, it is still displayed with a blue fill and a gray edge.
When reading a point layer that uses a MarkSymbol with a disabled fill or edge, the fill or edge is reintroduced to the layer.
-- Steps to Reproduce set to new value:
Old value:
more to come
New value:
In MapGuide Studio, create a layer based on a point geometry source.
Edit the layer's default symbolization and uncheck the fill or the edge.
Notice that the symbolization preview now displays a blue fill or a gray edge.
Save the symbolization change and save and close the layer.
Reopen the layer and notice that the fill or edge has been reenabled.
-- Summary changed:
Old value:
Mark Symbols not saved, always display fills and edges
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
