[mapguide][MG108][Modified] Mark Symbol changes not saved; removed fills and edges displ...
Ben Trumbore ben.trumbore at autodesk.com
Tue Mar 14 15:18:40 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG108
Type:
Defect
Artifact ID:
MG108 (Mark Symbol changes not saved; removed fills and edges displayed anyway.)
Modified by:
Ben Trumbore
bentrumbore (ben.trumbore at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
There was stylization code that replaced the invisible colors of missing fills and edges with blue and gray, respectively.  This has been removed.
The MdfParser created MarkSymbol objects that always contained fill and edge objects.  The default objects are now removed and are only reinstated if the parser finds appropriate definitions in the layer data.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
